watty
New Registration
The rear indicator is intermittently on the blink (pardon the pun). The tale-tale fast-blink of a blown bulb is misleading. I've changed the indicator bulb and checked for voltage. There's no 12vdc at the rear, passenger side, light cluster indicator when it happens and I don't know where else to look. I would like to check the next connector back along the line but not sure where it is. I suspect an intermittent open circuit at a connector sowehere. Any suggestions.
