A190 DIY service how to reset assyst & oil drainer devi
Status
Not open for further replies.
nickh
After thinking long and hard, now the A class is out of warranty and we intent to keep it for decades, I am going to do DIY services , following the manual. Genuine MB parts of course.
Does anyone know how to reset the assyst service indicator? also where can I get hold of one of those oil drainer devices?
That should save thousands of pounds, bearing in mind the depreciation from new.
kiwi_bloke
New Zealand
ive got no idea so ill just make assumptions :p
umm is it the "service light" your talking about? if it is i believe you have to get it reset by computer....
Oil drainer device? ive never heard of it, if im wrong someone jump in here please.... to drain the oil, just undo the sump plug, am i right or am i rong?
cheers
josh
maybach
ok to reset your assyst.
Ignition on. Bring up the countdown
release the button
press and hold the button
turn the ignition off and straight back on again whilst holding the button
after 10 secs or so the assyst will reset
Good luck
sw67
This is from the aclass owners website
Reset Assist on A class
Turn the key to position 2 in the ignition lock and immediately press
button 000.0 twice within the space of one second.
Turn the key to position 0 in the ignition lock.
Press and hold button 000.0 Turn the key to position 2 in the
ignition lock. Keep button 000.0 pressed.
Service message with current remaining distance or remaining time
appears.
After about 10 seconds, an acoustic signal will sound and the service
display with the new starting distance or starting time appears for
about 10 seconds.
Release button 000.0
grober
Scotland
W204 C200cdi estate
Vacuum oil drainer
Sealy ( see any good motor factors ) do a vacuum pump type oil drainer for about £60. Ive got one and it works a treat. I think there are others on the market. Boat chandlers often stock them for draining marine engines. cheers
Status
