MDC1992
- Apr 9, 2021
- A200 W176 2014 2.1L
Really need someone’s help!
I’ve had multiple mechanics look at the car and no one can tell me what’s wrong with it....
The car went into limp mode and the EML come on over the winter following a change of Control Units on front passenger running/indicator light (due to the amount of moisture)
I have the following faults codes coming up from my own ODB scanner:
P0473(12)
Raw code: 047312
ECU: Engine control unit
Status: Confirmed, Test failed since last DTC clear, Warning indicator requested
OBDII: Exhaust gas pressure sensor - high input
Mercedes-Benz: Exhaust Pressure Sensor High
============2==============
P0108(12)
Raw code: 010812
OBDII: Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - high input
============3==============
P0473
Raw code: 0473
Status: Pending
============4==============
P0236
Raw code: 0236
Status: Pending
OBDII: Turbocharger (TC) boost pressure sensor A/supercharger (SC) boost pressure sensor A - range/performance problem
============5==============
P2227
Raw code: 2227
Status: Pending
OBDII: Barometric pressure (BARO) sensor - range/performance problem
============6==============
P0238
Raw code: 0238
Status: Pending
OBDII: Turbocharger (TC) boost pressure sensor A/supercharger (SC) boost pressure sensor A - high input
============7==============
P0108
Raw code: 0108
Status: Pending
============8==============
P0473
Raw code: 0473
Status: Confirmed
============9==============
P0108
Raw code: 0108
Status: Confirmed
I have already have the following changed or tested:
MAP sensor replaced
Boost pressure sensor replaced
Cloned ECU tested
A couple wires from engine to ECU fixed
When I got the Boost pressure sensor replaced, it worked for the evening, but the car now goes back into LIMP MODE and the EML on.
I have tried to clear the codes, but even with the EML off, it is still in limp mode.
Any one else experienced this or can help please?
Cheers
P0473(12)
Raw code: 047312
P0108(12)
Raw code: 010812
P0473
Raw code: 0473
Status: Pending
P0236
Raw code: 0236
Status: Pending
P2227
Raw code: 2227
Status: Pending
P0238
Raw code: 0238
Status: Pending
P0108
Raw code: 0108
Status: Pending
P0473
Raw code: 0473
Status: Confirmed
P0108
Raw code: 0108
Status: Confirmed
MAP sensor replaced
Cloned ECU tested
Cheers
