Hi everyone hope you can help with a problem I have which maybe be a simple fix. I replaced a pump due to low pressure and a nsf shock due to a leak. I managed to get the suspension all working after until I noticed a leak from the osf shock flexi pipe union. I removed the shock and the pipe with the quick release union which went to a block on the nsf wheel arch. The pipe was replaced and then all parts replaced. Now here lies the problem, I have various faults recorded. The pump started off not producing enough pressure but eventually kicked into life . I have critical level rear left,calibration of the plunger travel sensors not successful,load adjustment not successful and fault in the front left Plunger travel sensor. I have undone the bleed screw on the osf pipe and no flow of oil, I undid the pipe union that goes to the block and no oil flows . The pump pressure is reading 190 , the suction sensor component voltage shows no reading on live data just 0. There is voltage at the connector. Just need a bit of advice how to go about sorting before throwing parts at it. Thanks if you can help.
