ABC on CL600 ...
Hi Folks, I have noticed a couple of 'niggly' little problems with my 2001 CL600 recently and want to address them before they turn into part of Lewis Hamiltons salary for next year ...
There is a (very) intermitent problem with the ABC system whereby, when starting up, the red 'ABC, Drive Carefully' diagnostic comes up on the dash, this usually disappears after a few minutes (carefull) driving, but occasionally can last for a day or 2. I've checked the fluid level in the reservoir and although a bit low, they're not on 'min'. The problem only occurs when starting the car, never while in mid-journey.
Any areas to look or advice on what to do would be gratefully accepted. And if anyone could let me know the best fluid to top the level up with I would also appreciate.
Thanks in advance
Andy
BlackC55
South coast
C43
Dig deep. Its going to be expensive.
It is probably either a suction restrictor valve problem or a pressure sensor fault.
Please be aware ANY fluid leaks need to be fixed first. Normally there are many!
I have alot of experiance with ABC and have been on the MB training course for it.
Do have a look on the insides of the tyres- wheels, any leakage will show there, also any spots on the drive way.
When it is showing check ABC visit workshop you have no height control, always turn off and restart.
When it is RED your car is too low
A
Thanks for the seriously quick replies guys.
I've noticed no leaking at all that I can see and although the level is lower than I think it should be, it has remained constant for a month or so since I last checked it.
One thing I have noticed, although it could be pure coincidence, is that it seems to be happening when the weather has been wet, no idea if this has any influence on matters.
...when you say 'dig deep'? ... how big a shovel will I be needing?!
Thanks once again,
Andy
hagarfriend
Hampshire
1996 s280dIesel in Spain. 2003 CL 600. Now gone. 2004 CL600 v12 bi 2008S320L diesel. 2008 CL63 AMG
I have just purchased a 2001 cl600 and it is limited to 130mph. I see on your thread you have had yours derestricted, can you reommend to me who carried out the work. I am in reading in berks
many thanks
clint
This is rather an old thread,, you could have a word with STAR motor services in Caversham
MissyD
Essex init
www.depop.com
E200 1993, E300 Coupe 2019
Probley find that the limit has been set to 130mph on the dash for winter setting, any CL will doo 155mph,
Cole
Cole
Already covered on his other post,,and yes the winter tyre setting is activated, just finding the menu is the problem now in the cluster
