ABC time, again.
gassed up
liverpool
2011 C207 350CDI;2010 C207 350CDI sport;2010 SLK300;2004 C209 320;2000 C208 230K;
Hi Guys, the replacement pump on the SL500 has started knocking. Interesting thing is the knock is intermittent. Sometimes a real rattle, sometimes silent. Anybody any experience of this, is it trapped air?
Where did you source the pump and how long ago?
G
gassed up
liverpool
eBay purchase from Poland about 12mths ago. I did not exchange the old pump because I will buy a seal kit and rebuild it. My personal philosophy when approaching a challenge/technology I have no previous experience of is to start cheap - possibly f**k up, learn and skill up. The alternative is to spend big and still get it wrong
Craiglxviii
Cambs UK
Spend £560 and buy a new pump from MB. It’s really not worth the risk to the entire system; 4 struts @ £700 each plus £2500 of valve blocks...
G
gassed up
liverpool
I take the point but why the knocking coming and going, any clues?
Craiglxviii
Cambs UK
G
gassed up
liverpool
drmw
Yorkshire
www.autonomed.co.uk
A bit under - back struts - "The original Mercedes part is £2612+VAT + fitting or, we can source an OE quality part from Germany for £1450 + VAT + fitting." (which is why mine went!!). Fronts about £1400 each.
MB do them cheaper than that! I'm sure I've seen prices of £880 for struts from MB.
OP - you could try a rodeo test (on Star) to see if it does it under any particular action.
drmw
Yorkshire
www.autonomed.co.uk
There will be some room for negotiation, but not a lot. That was 6 months ago, my SL63 (not sure if there is a material difference) and the "quality part from Germany" bloke was an MB independent with a good reputation
flowrider
SL500 (R230)
I wouldn't be paying those prices for my R230. Reconditioned struts are getting towards the £500 point.
Craiglxviii
Cambs UK
OEM new struts are available from AliExpress, for the 230 for ~£700 per corner.
Craiglxviii
Cambs UK
Is the flow restrictor the one that sits on top of the pump with a 2 pin plug?
That’s it yes. Not available as a separate item though.
G
gassed up
liverpool
I've still got one on the old pump. I didn't exchange it because I'm going to rebuild it with a new seal kit. I'll try swapping the flow valve.
Craiglxviii
Cambs UK
Did you buy Viton seals?
G
gassed up
liverpool
I ain't bought the kit yet, I assume that I'll have to source it from the US of A.
Craiglxviii
Cambs UK
You know that you have to heat treat the end of the shaft to remove & refit the pulley..?
G
gassed up
liverpool
No I didn't, do tell. Is there a resource that I can access?
Flyinspanner
Ruislip
Think there was a member on here, (or maybe the ‘other’ Mb site) who was selling viton kits.
Or if he has none left may be able to give you a list of sizes/ suppliers.
