About w210 yr 96 ?
Daniel2021
W210 E240 /2000/v6 2395 cc
Hello MB guys ,i have a friend which he has a w210 yr 96, 6 cylinder ,he telling me that model have a manufactured defect in the ECM and also the 202 model is the same ,he searched on a Russian MB forums ,he found that defect is found in w210 produced before 97 and they made a succeed modification on the ECM to avoid that defect and they proud to made that modification on the german made ...anyway is that right ? Especially my friend's w210 begin to act wired ,it always turned off and when he ignition it stay for 30mins and then it turned off, after checking every thing in the ignition cycle and fuel pump and every thing you can imagine,still the same but after he checked a Russian MB forums he found that defect, so he change all the ECU ,ECM unit with another one and the car works good again but is that defect ll be appear again because he didn't made the Russian modification which they claimed they did it because he didn't know what is it...so friends im waiting your opinions ..thanks a lot.
mioba
Nottingham and Köln
a 24 year old car and your talking about a manufacturing defect, sorry.
D
Daniel2021
Yes sir, more than 30 yrs ,that defect was completely modified after yr 99...
Ps: it is not my car ,mine is w210 yr 2000
brandwooddixon
Wolverhampton
S63 Coupe 2014
A defect in the engine ECU?
I had an early W210 E320, which had the straight 6 engine and ran it to around 170k miles without issue. I guess that your friend's is the V6.
To be honest it sounds like crankshaft sensor failure behaviour. I can't say that I've ever seen anyone state that there was a manufacturing defect with the ECU
