Gastro
- Aug 27, 2005
- Age
- 81
- Location
- North East Hampshire
- E280 Estate W211 Sept 2007
My 1992 (late)W124 E280 has just cracked 110k and continues to delight with the exception of one aspect of its behaviour. Unlike all other MB's I've driven of this type, the throttle is very sensitive when opened from rest. Consequently the gearbox grabs first and assumes full power acceleration is being called for every time I'm moving away from a standstill. Consequently, manoeuvreing in confined spaces such as multi storey carparks results in a series of 'lunges' in both directions entirely beyond my control, and patently not good for the car in the long term.
I've suspected the setting of the control pressure cable and examined the Haynes manual for guidance on adjustment without success. Mine is equipped with the HFM injection system, and the manual begins by saying 'remove air filter housing'....but this is on the opposite side of the engine bay and is irrelevant to cable adjustment on my version. I've looked closely at the complex set of levers and cranks where throttle cable and control pressure cable converge and can't for the life of me see any pointers to align as the book suggests. In fact the arrangement on my car seems to differ from those shown in the book.
The control pressure cable has a red sheath. Should I loosen or tighten it to create more progression in the throttle from idle?
Perhaps you will have other ideas for me to try?
I'm a qualified but now retired senior technical motor engineer with 46 years of experience but not on the MB product until I bought this car last August.
Many thanks.
Many thanks.
