4 new sensors fitted today... the originals almost look like new
not sure which end is which, or which was left and right as I didn't put them on
the longer ones, part number A221 540 0317 readings were
373 k ohm and 402 k ohm
of the two short ones, part number A221 540 0117 readings were
393 k ohm and 390 k ohm
part numbers they were replaced with was
A221 905 7100 (front)
A221 905 6000 (rear)
rather perversely I see in USA, same fronts at 65 dollars ! and
A221-905-73-00-80 / Remanufactured Rpm, listed for the rears
Something has just caused the same module on my k1300 to go mental as I said earlier, with
2786 - Front-wheel speed from ABS implausible
if I turn off traction control the bike comes out of horrendous limp mode
thanks, got other issues with seized pistons in front calipers that's more of a concern....
sensors was more a precautionary measure as you guys having issues and that I'd had park brake odd twice and esp light once in last 4 weeks, the different readings on the longer ones (which on parts drawing and numbers must be the fronts.... ) suggests on the way out so worth doing (I hope)
garage seemed to think park brake release is may be related to other stuff.... I don't know what gives it the signal to release as u drive away, it worked yesterday OK
Hi Alex
Your issue sounds slightly different in my msg. Cleared after driving 15ft.
But if you cleaned the sensors and reluctor rings and its still there, barring low voltage which I am sure you have already checked.
It might be worth resetting the EPB.
I know, I know, wtf has the EPB got to do with and abs - esp issues.
Note mine also had 3 sensor fault codes advising a viz inspection.
Only takes 5 mins and seems to have cured mine. (Far too early days, but whereas I got this Msg. On EVERY start!
No messages since last Friday.
To Reset:
Get rid of the message (by driving left and right )
Stop put in N .. dont press brake firmly to get HOLD. Stop engine (the EPB is not applied).
Switch Ign. Back on
Then press EPB handle for a few seconds .. you see the EPB red icon light.
Switch off engine.
Restart hopefully with EPB icon lit.
Pull EPB Handle for > 12 seconds.
Turn off engine.
Restart and no more msg.
Sounds crazy
... but N47-5 is my ESP controller, and its linked to A13 my EPB switch, via the CGW N93.
It also goes throught the front and rear SAMs (note at various times I could get fault codes, saying Sensor readings from front axle, then later the rear axle were implausible).
I did clean the sensors and the rings.
Well when I say cleaned the rings ... I rolled up lint free cloth sprayed a bit of brake cleaner on it . And pushed it into the sensor hole and rotated the wheel. Dirty grey/black slightly greasy chalky stuff came out . Did this till I could see what looked like ground grey steel, with a sort of regular pattern on it ... mine didnt have the classic deep cogs. .....
This may have been totally the wrong way to do it? And took ages .. a truly hateful job!
But I assume its a hell of a lot cleaner in there, than before .. and seems to work.
Note this cleaning in its own, did Not stop my messages.
this thread is rather old...
My brakes where getting hot 7 out of 8 pistons in the front calipers were seized completely solid (good work for a 50k mile car that has been cherished) we should learn to appreciate quite how well they developed these cars ...to empty your wallet.
It took me 3 hrs to remove the pads on one side, just to find the pistons won't move at all for anybody, 6 hours later I didn't spend long trying on the other side - MB grangemouth do great deals on refurbed calipers and their price on genuine pads and discs are shocking (in a good way)
We then found here with 6 owners in the space of 6 months (and I see the same years on, with newer cars on a big USA forum) ALL the W221 ABS sensors die to a timetable Mercedes carefully developed...
Not sure the exact reason, but STAR tell you to always do both on the same axel at the same time. For a rusty bit of copper wire built to a quality standard even China would frown over, the price is shocking (in a very bad way)
Sorry for you its defo an infectious desease!
Ta Da
No doubt shortly to be accompanied by these two cycling repetatively
View attachment 43053 View attachment 43054
And I dont even have run flats!
Btw Botus Mobilo think they have found the fault.
A corroded earth to the ABR (ESP) controller.
Low loading it to Dealer tomorrow ... ref cant undo nut on body stud ... locked solid!
If I wasnt so ****ed off I would have grabbed a jump start lead, and connected it to the main earth point lol
Just thinking how many earth points like this there must be that could give me future fun and games
Considering the price of the car, they could have used gold plated contacts for the brakes, ABC and Comand units or at least the exposed connections.
