Hi All
I have a 1998 CLK320 W208 with the above fault lights illuminating.
An independant has downloaded the memory and found the code 5101 along with C1025 (which I know is a CAN fault relating to the BAS system)
I recently disturbed the front ABS sensors whilst fitting some new suspension, any ideas what 5101 is......?????
I have also changed the brake switch was had an intermitant fault on it.
many thanks.......................
