ABS Light On
Status
Not open for further replies.
nas
My ABS light has come on in my merc 190E 2.3 16 it just come on while i was driving out the blue, i try turning the car off and restarting it but it still is on. I hope you can help me as i have never come across this before.
heckflosse
Derbyshire, England
The SRS light occasionly comes on on my E220. I find if I disconnect the battery for an hour or so it's fine again. I tend to have the problem every 4 weeks or so.
The same may apply on the ABS. Although If it keeps happening I'ld get it looked at.
Loff
Cumbria
Nas
I have an A class and my ABS and brake warning light came on recently - it was a 10 amp fuse for the brakelight switch on the brake pedal
Loff 8)
N
nas
Where abouts is the fuse situated for the ABS if there is one? coz i cant find one in the fuse box under the bonnet for the ABS.
ronaldalfred
llanelli wales uk
I had the same on my 1985 280se,it turned out to be a faulty relay,it's a small squarish metal bit in the fusebox.You will need to get it fixed as it is an MOT failure if it doesn't go out after the engine starts.
Ron
Status
