ABS Light reset
opps-man
Liverpool
My year 2000 C220 CDi Estate W202 was involved in an accident,
I have carried out all the repairs to the bodywork suspention and brakes,
My dash has the following lights illuminated. ABS,BAS/ESP, and SRS.
What cable connection do I need to clear the lightsand where is the plug located? I will buy the nessasary software to install on my laptop.
I have seen referance to 16 pin,36 pin and OBD11 Conectors but do not know what connection that my car has.
Can anyone help?
djb
uk
just a thought
dont supose the abs sensor at the wheel is not close enough to the disc or whatever it gets its motion sense from?
O
opps-man
Liverpool
ABS sensor bolts on to the hub carrier and I dont think it is adjustable, But thanks for thr thought.
Normally replacing the brake light switch just above the pedal £8.75 held on with a 17mm nut solves the problem.
Malcolm
jberks
Daft question but have you driven it?. After reconnecting the battery, you have to swing lock to lock a couple of times to resync the steering angle sensor, or you'll get those warnings.
The SRS will need a computer reset.
O
opps-man
Liverpool
Not such a daft question, but yes I have driven it, I am currentl doing 85 mile a day to work and back.
Have tried swinging the steering from lock to lock to no avail, lights are still on.
Wajid
same problem...
hi oops...
ive recently bought a damaged merc c200 auto and seem to get the same lights on as yourself...
dunno what it could be.... not been to reset the car yet for the airbag...
please let me know if you find an answer...
cheers
O
opps-man
Liverpool
Wajid said:
hi oops...
cheers
Hi Wajid.
I have just bought the software and OBD link cable to try to find the fault code and erase the fault along with the warning lights.
I will let you know how I get on.
Cheers
Don.
