ABS or other electrical brake problem on W124
Status
Not open for further replies.
Anders
New Registration
II got a weird problem with the brakes. Brakes have been working fine until yesterday except for ABS.
But now both front wheel brake leaves on, not always but sometimes. Could this be caused by a failing ABS or other failing electronics?
The condition of brake pars checked and seems to be okay.
I would understand the one wheals brakes should leave on but always both and at same time?. And then I have to stop the car and wait or try to reverse I helps sometimes.
The ABS lamp lighting every ~15 minutes, and the rmp meter dies at the same time.
It usually takes 5-60 seconds and then it works again. (But this problem have been last 5000 km so I don?t now if it is a other problem)
Or could someone tell me how to temporary disable ABS to find out
if it is causing the problem.
The car is a 300D-88 with ABS
Status
