Abs problem
Vinnysian
C class coupe c180 kompressor 2007
Hi got mercedes w203 c230 kompressor
Had the abs light on last week abs would kick in at low speeds.had code p2400 and p1860.both to do with right rear wheel rpm signal.i change the abs ring yesterday and the same problem.same codes.
Any one the problem????
Uncle Benz
West Sussex
Mainly Mercedes
Did you replace the reluctor ring, the sensor or both items?
Vinnysian
Vinnysian
I replace the the ring and sensor.
Still the same problem.
Vinnysian
Vinnysian
Ok il check
Vinnysian
Vinnysian
Yea I put 4 tyres about 3 weeks ago
After that it started
Vinnysian
Vinnysian
Got 225 45 17 on front
And 245 40 17 on rear
Uncle Benz
West Sussex
Mainly Mercedes
Measure the diameters, check you don’t have a rogue tyre on the right rear, especially not a 245/45/17. I’ve seen that before. Maybe swap the rear tyres left/right, see if the fault moves
Vinnysian
Vinnysian
I try that
cadman777
Registered
1999 C230 Kompressor (W202)
Same with VW.
They have a "Reset" button in the glove box to reset when tires are changed or if they're not the same.
