evening all, what a great day i have had (not). Does anyone know if the ABS fault light activates if there is conflict with the autobox and speed sensors. I have had fault codes read and the only fault codes reocurring is speed sensor, no ABS fault light showing but the ABS is working and does show a fault if i disconnect anything on the ABS circuit. The valve block and conductor plate in the box is brand new from mercedes so should not be any problems there. Any ideas.
cheers
karl
cheers
karl
