ABS warning light, ESP and Brake assist, cruise control, inoperative.
a.chappers
Manchester
E220 cdi 2008 Avantegarde
Hi, I am getting these warnings intermittently on my 08 WDB211 E220. They go off when I stop and restart, then it happens again. Should I be worried? How do I trace the root cause and fix please? Many thanks, Chappers
mersum1es
Finland
read the codes (SDS preferred), check your main battery is at full charge/health
onefortheroad
uk.
Possible brake pedal switch failure , search you tube ...
Uncle Benz
West Sussex
Mainly Mercedes
Or a reluctor ring on the back. See how important a code read can be?
onefortheroad
uk.
moral of the above posts is get the codes read.
Indeed , speaking from experience and even then it was a loose earth cable. Which star didn't point out.
mattkh
England
A160 W168 1999 1.6
I would like to know how the problem was cured, please.
There is not a one shoe fits all repair for the above. You need the codes read by a competent indy with a adequate reader.
A
a.chappers
Manchester
It has suddenly settled down. I am waiting for the fault to reappear then take it in to get the codes read. Will post when facts become apparent. Thanks for all interest.
mattkh
England
A160 W168 1999 1.6
Thanks for that.
It seems to point to a low charge in the battery.
A
a.chappers
Manchester
That is interesting Matt. I will put it on charge to give it a good boost.
