ABS Warning
Brockuk
c220 estate 2011
My abs warning light is on plus traction control warning knocking out Cruise control, stop start , tyre pressure info etc,
Scanner showed front right sensor also engineering mode on comand showed same,
replaced sensor lead with new from GSF not a cheapo off ebay but no change.
Any ideas what to try next.
Thanks in anticipation.
Vehicle is 2011 C 220 estate.
There’s been more than one thread on here where aftermarket wheel speed sensors have given the wrong readings straight out of the box.
Try a genuine one - or move the sensor and see if the error moves
B
Brockuk
c220 estate 2011
Thanks Blobcat will try swapping front sensors around if it shows as working will have to bite the bullet and purchase Mercedes one, Thanks again.
B
Brockuk
c220 estate 2011
had the old sensor lead checked in garage today was told it was ok nothing wrong with it, So any ideas where to go from here have been reading common fault causing ABS light can be brakelight switch, but would that cause Traction control light and tyre flat not operating also not working Criuise , Parking feature and Brake hold, Also stop start
davidsl500
Have you checked the condition of the ABS Reluctor ring? If the sensor is okay then it maybe the other half of the equation that is causing the faulty readings - check its not rusty/clogged/missing bits!
AlanGunn
Anglesey
2013 C250 sport+ 2.1d
Look for rub marks on the sensor tip that is a sign of a swollen reluctor ring.
A temp fix is a washer but as said only temporary fix.
Malcolm Johnson
East Yorkshire & Suffolk
R230 (M273) & W221 S350 bluetec
A icar soft scanner (or any scanner i guess) will confirm which sensor is dead. I replaced mine with a Bosch sensor 2 years ago on the S tank.
B
Brockuk
c220 estate 2011
I had used a icarsoft pro scanner as well as engineering mode on cars head unit both showed front right sensor which I replaced but did not cure the problem so am left scratching my head at the moment have got to check reluctor ring if possible.
B
Brockuk
c220 estate 2011
Just an update wheel sensor purchased from GSF is not working, checked by using the one that I
knew worked from other wheel. So doing what I should of done in first place ordered 2 from Mercedes as I have been advised by Mercedes mechanic probably better to replace both fronts at same time, as in the past he has replaced one side only and other side gave up few weeks later on a vehicle.
Tel: 020 8863 9233
