ABS wiring diagram
Lau_tm
w169
Hello,
Does anyone have the wiring diagram for ABS system for a W169, 2004, 200CDI? The module from the pump does not get power anymore.
Thanks!
mattkh
England
A160 W168 1999 1.6
Hello,
Thanks!
Do you have the fuse/relay chart which is normally with the battery under the floor.?
If you do, look for a fuse or relay for the ABS.
If there is, then check the fuse or the relay.
L
Lau_tm
w169
Fuse and relay are OK.
www.ckinsurance.co.uk
