Accelerator Pedal Valve Sensor
swells14
Hello everyone I own a 2000 E-320 delivered in the US. While I enjoy the vehicle a recent problem has developed. In that after starting the vehicle will idle and then shut off. I been in traffic at a traffic light with my foot placed on the brakes only to have the vehicle shut off. When trying to restart the engine keeps turning over. I've been told it is the Accelerator Pedal Valve Sensor. Has anyone heard of this ? Is this something I can do myself ? Finally anyone know how to replace the bulb behind the a/c heating control. Appears the bulb must have blow as when I turn on the headlamps the light no longer comes on !
swells14
This vehicle has the automatic climate control are there special keys needed to remove much like the radio ?
Yes in the UK the keys cost £1 from any MB dealer
swells14
Thanks vehicle only does this when idling. I can start in leave it in park warms on then all of a sudden shuts off. In traffic stopped at light same thing
Then I go with SAM and the CPS ½ the price from a Bosch service center
swells14
Since I'm not familiar with the part is it actually called a crank sensor ? I was told today by the dealer they think it is the accelerator pedal value sensor part#0125423317. Is this the same part you are referring to ?? Thanks for your help !
No this is not the same part, and I cant see how the pedal sensor could stop the engine, as Idle is nothing to do with it,,even if you lost the throttle control the engine would not stop
swells14
Ok so what is the CPS ? Sorry as again I'm not familiar with the part
The CPS is a sensor that sits above the flywheel to set up the electronic, this has a habit of failing when its warm. they should have plugged the car into the STAR system where the fault should be recorded,,if the car starts again immediately then it may not be that
Cole@MBS
www.mbssouthampton.co.uk
Agree with Malc, you could unplug the pedal and it would still run, still say for that engine its a crank sensor, 0001532828 part number!
swells14
Thanks Gentlemen I'll give it a shot see what happens !
If you have an ohm meter you could test when faulty,,it will read near on open circuit,,when good 1KΩ
swells14
Well the part came in $54 US replaced myself a little difficult to get to but started up fine and so far not shutting off. Thanks for the replies and help naturally I question the knowledge dealer- As in the same estimate they recommened the following being done-
Shifter Bushings $113- What are these & where are they located ?
Rear Spring Link Bushings $535 " "
Differential Rear Seal $851 " "
Rear Flex & Front Flex Disc $507 " "
Rear Main Seal $918 " "
I question if all this is really needed as the vehicle has 70,000 miles & no indications of a leak that I can see-From the posts appears the dealers overseas are just as bad as the ones in the US.
If you are not getting any clonks or noises from the drive train, wait till it really needs doing,, they are mainly referring to the prop shaft and rear suspension parts
swells14
  • #17
Thanks are any these items DIY items ? I checked the section & did not see them unless of course I have the part names wrong-
Cole@MBS
No, not unless you have a good ramp and workshop,would like to know what they are talking about "shifter bushing"?
Well they are saying that the diff is leaking oil, so make sure that the vent is clear.
The prop shaft joining disc are a DIY job
They say the rear end main seal replacing, dont know if they mean engine or gearbox, is it dripping oil ander the bell housing
swells14
  • #20
Sorry I don't know where the pro shaft joining disc are ? Also I'll exactly what they mean regardng the the rear main seal. Currently there is no oil deposits beneath the vehicle when parked. What & where is the bell housing ? In relation to the diff where is that located so I can check the vent as indicated. Again, sorry for my lack of knowledge here but I'm learning as I go !
