Access limited to RHS headlight SL320 R129
R
roadster198
I may have to check the connectors on the RHS xenon headlight on my SL320 however the water bottle seems to be blocking the headlight covers. Has anyone a method on how to access the bulbs do I need to remove the washer bottle? :shock:
Yes the bottle will have to come out, but do not lose your bottle when doing this and be carefull with the very high voltages on these öamps, also do not turn the headlamps on with a bulb out
R
roadster198
Can I disconnect the battery to do this?
Any instructions on how to get the bottle out TV?
You do not have to disconnect the battery, it is safe when they are turned off
I can only check later in the day on the bottle
