there is a hole in the aircleaner top cover.
this leads to the mixture adjusting screw-you need an allen key to adjust it.
it may have a tamperproof plug which has to removed before adjustment takes place.
i have not touched mine as my car has a catalytic converter and one cannot adjust the mixture as the co reading at the tail pipe would almost nil,if the cat is working-special kit required.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
