Anyone know how I can adjust the parking brake on an ML 270?Its very poor at the moment and I need to adjust it but dont know where to do this.Any help would be appreciated.
Firstly you need to adjust the shoes correctly. to do this you need to wind up the shoe adjusted through a wheel bolt hole in the rear disc's. Adjust it untill it locks the disc then back it off 3 clicks so the wheel/ disc can turned. recheck the pedal, should be vasty improved.
It is much easier to do it with the wheel off. use a flat blade screw screw driver through the hole, it looks like a small toothed wheel inside the disc drum.
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
