roblloyd
- Jan 5, 2010
- R129 1990 500SL
CAN ANYONE THE ME WERE FAULT CODE NUMBER 6 is on the car and the right name, MB do not know got the past 4.30 and was told everyone gone home.
Adaptive Damping System (ADS)
Models Model Years
129.061 129.066 129.067 129.076 1991-1995
140.032 140.042 140.051 140.057 140.070 140.076 140.134 1991-1994
FAULT CODE TABLE
DTC Readout Possible Cause of Faults
1 No fault found
2 Adaptive damping system control module
3 Body acceleration sensor
4 Wheel acceleration sensor
5 Steering angle sensor
6 Front axle solenoid valves 1
7 Front axle solenoid valves 2
8 Rear axle solenoid valves 1
9 Rear axle solenoid valves 2
12 Right front axle vehicle speed signal
or
ABS Signal
13 Oil level switch (ADS)
14 Steering angle sensor not activated/initialized
15 Comfort or sport switch (ADS) short circuit
17 Vehicle load sensor
18 Adaptive damping system warning lamp
19 Volts supply too low
20 Steering angle sensor
21 Volts supply too high
22 Comfort or sport switch (ADS)
Rob
Models Model Years
FAULT CODE TABLE
1 No fault found
or
ABS Signal
Rob
