flagstaff
just changed the cyl head gasket on my 93 e280, and on reinstallation the car won't start. i double checked the crank/cam timing marks, and have found that when the cam marks align correctly, the crank is too far advanced to be in correct timing with the cams. my question is, does it matter whether the crank is 180 degrees out, relative to the cams, as long as it is positioned correctly and i then proceed to rotate the cams so that they control the valves as per no. 1 cyl on firing stroke?
i haven't explained that very well. what i mean is - the crankshaft doesn't know which is the firing stroke, does it? this is down to the cams .... or am i missing something?
i just need to be sure to get this timing thing right, before proceeding to any more serious possible cause for non-starting.
what i've got, then, is the crank positioned with the O|T (TDC) mark at the correct position relative to its marker on the timing chain cover. and i want to now unhook the timing chain and position the cams so that their alignment holes line up with the face of the cyl head.
is this ok? sorry to sound confusing ... i think it's because i'm confused.
