D3Less
The oil separator on my C270 has a slight weep from around the top and also I seem to get quite a lot of oil going down the breather tube. I replaced the connector between the 2 tubes (the one with the electrical conection) as this was leaking but I still seem to be loosing a bit somewhere.
Can anyone tell me if it is an easy job to change the separator and also is it faulty or should quite a bit of oil be going down this tube?
The car is running fine and has no problems with oil in the MAF / air filter, just a bit annoying as this is the only oil leak
I am talking about number 53 on here http://www.detali.ru/cat/oem_mb2.as...648716.649&CT=M&cat=21T&SID=01&SGR=075&SGN=07
Thanks in advance
Cliff
Thanks in advance
Cliff
