Advice on changing front engine mounts on ML W163
peters877
newport
ml270
Hi, Can anyone give me any advice on changing both engine mounts. What is the best way to go about tackling the task. Any info welcome.
WG M-B
North west london
C63 Wagon in black
They are not the easiest of the models to be fair. Access is easiest gained through the inner wheel arch liners. The n/s mount is a bit more tricky than the o/s.
panason1c
Somerset, UK
Mercedes ML270CDI, VW Polo 1.9tdi, BMW K1200RS
As mentioned, remove both inner arch liners. The engine will not jack up high enough for the engine outriggers to clear the engine mounts, which means you have to also unbolt the outriggers from the engine block to enable removal of the mounts. (applies to both sides)
Have to disagree, done many ML mounts, never removed the outriggers, that me using a ramp tho, might be diff on stands etc!!!
panason1c
Somerset, UK
That's useful to know.......Yes, i did mine on axle stands, just couldnt get the engine high enough to clear the mounts........ i'll use my mates ramp next time!!
Much better on a ramp and a good gearbox jack, still a crap job!! would wanna try doing it on the deck!!
WG M-B
North west london
C63 Wagon in black
They do both come out without taking the outriggers off. Just some gentle persuasion required
P
peters877
newport
ml270
Thanks guys for the info. Think i`ll take it to a local garage.
