antorumbo
- Feb 21, 2021
- Location
- Altrincham
- 2008 Vito auto 120cdi W639
Hi All,
Appreciate any feedback or guidance anyone can provide for my 2008 Vito 120cdi auto (77k miles) before I give up and let a garage take over.
After little use during lockdown in the UK the battery died on MOT day so I jump started via the battery connections under the bonnet. Soon after, an ABS error started appearing on the dash and the auto gear selector would get stuck in Park. Now, the gears are not selecting or changing correctly and the dash doesn't show the correct great position either.
A few years ago the DPF was replaced after it caused limp mode issues. This year, a faulty alarm kept going off so I removed it.
I read, cleared and re-read the fault codes today (below and attached). There were a LOT!
I've replaced the brake light switch but this hasn't made any difference. One of the glow plugs is stuck and spins so can't be removed.
I used the correct dipstick to gauge the transmission fluid today but it was pretty inconclusive as was either dry or completely covered.
I'm now thinking of replacing the 13 pin O ring transmission adapter plug along with servicing the transmission fluid and filter. I wonder if I should replace the transmission control unit too?
I've recharged the battery and it starts but maybe a new battery is still needed first? Keen to get your thoughts.
2137-2
R9/5 (Cylinder 5 glow plug) -Short circuit
2208-1
CAN bus -CAN signal 'Brake signal' from control unit ESP is implausible
2226-1
Transmission control -There are current fault codes present in control unit EGS. [Fault 9]
2210-1
CAN bus -No CAN message from control unit EWM
430A
The line to component S9/1 (Stop lamp switch) has a short circuit or open circuit
51C1
MIL ON&Stored&Current
N1 5/5 (Electronic selector level module (ESM [EWM]) is faulty (Current gear)
912A
A1 (instrument cluster (KI)) - The control unit is faulty
B1031
Component N1 0 (Signal acquisition and actuation module (SAM)) has ground interrupt.
B101 A-001
Overvoltage or undervoltage in voltage supply (Tml. 30). .Undervoltage
B1OE1
No communication is possible with component H3/1 (Battery-operated horn)
C103
Fault in CAN communication with control unit N1 5/5 (Electronic selector lever module (ESM [EWM]))
D408
CAN signal 'Stop lamp switch' from control unit N30/4 (Electronic Stability Program (ESP)) is missing or faulty
P0705 $07E8
Transmission range sensor A circuit (PRNDL input)
P1405
$07E8 MERCEDES(DIESEL)
Please refer to vehicle service manual
P1750
The supply voltage of the control unit is too low (undervoltage)
Selector lever position P INACTIVE sensor
Selector lever position R INACTIVE sensor
Selector lever position N INACTIVE sensor
Selector lever position D ACTIVE sensor
Selector lever position - INACTIVE sensor
Selector lever position + INACTIVE sensor
Locking solenoid OPERATED
Voltage 2.9V
P242F $07E8
Diesel Particulate Filter Restriction Ash Accumulation
P2454 $07E8
Diesel Particulate Filter Differential Pressure Sensor Circuit Low
2137-2
2208-1
2226-1
2210-1
430A
51C1
912A
B1031
B101 A-001
B1OE1
C103
D408
P0705 $07E8
P1405
P1750
Voltage 2.9V
P242F $07E8
P2454 $07E8
