aerial on a w126
simon_wall69
Stone, Staffordshire
I have a 560sel w126, which when I bought had no stereo. I have put a stereo in it now which seems to work fine but as the aerial refuses to rise I have no radio signal. Any ideas on if I can raise it manually?
Regards
Simon
Have you not joined up the aerial electrics to the radio
brandwooddixon
Wolverhampton
S63 Coupe 2014
Does your radio support elstric aerials? if so then there should be a output for that. It will trigger the aerial when the radio is turned on.
Alternatively there could be a problem with the aerial motor itself. MB connectors use ISO pin outs as a rule. Try applying 12V to the electrical aerial lead (NOT the antenna coax) and see if that raises the aerial. If not then it is possibly a fuse, relay or the aerial motor at fault.
