Air and cabin filters
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
I was going to order a replace set, but am I wasting money. Air filter were replaced 13 months ago at 43448 miles, and the cabin filter was done 25 months ago on 32890 miles. Millage is now at 52k. Not sure sure what the 'Mann Frecious Plus cabin filter' is much better than the standard? but we both have summer allergies and wonder if this would help?
I can get three filter for £75.
It won't do any harm (other than a minor dent in the bank balance).
Capra
Capra
Gloucestershire
Capra
Capra
Gloucestershire
The filters are fairly dirty, plus there seems to be some oil within the intake, is that normal?
bembo449
gainsborough , lincolnshire
I presume thats the MAF ( not worked on a 350 yet ) and so part of the intake set up , hot oil vapours run round the system at quite a rate of knots so I always would expect to see residue on parts connected to it , whats the other side of your cab filter like pal ?
Capra
Capra
Gloucestershire
Yep, I believe it is. I knew deisels were mucky but not this much. Would you replace the filters, they look a bit grimey as well.
Gazwould
C250 CDI
Normal petrol or derv crankcase oil vapour , they both suffer but the diesel is extra sooty from incomplete combustion of diesel molecules thanks to the egr .
The inlet manifold gets alot of the combined muck and can reduce the intake by 2/3 .
Causing poor efficency - less mpg , power etc and MORE emissions .
Capra
Capra
Gloucestershire
Is that what the crankcase breather tube thing was for? Would you change my filters?
Capra
Capra
Gloucestershire
Just thought, I believe you have to reset the ECU with star once this has been done, I think? :confused:
EmilysDad
Bury Lancs
ML350
But I've also been told by an indie, that the car will learn itself that the filters have been changed ... :confused:
Capra
Capra
Gloucestershire
Our cars are like urban myths. Surely needing star would just raise the service costs?
Gazwould
C250 CDI
How muc
I would get the FreciousPlus , how much ?
Capra
Capra
Gloucestershire
How muc
About £23 I think. But I realised i don't need them, it's the air filters that were done a year ago.
Gazwould
C250 CDI
You do...
It's not an ordinary charcoal pollen filter and deals with the issues of the diesel demonisation..
EmilysDad
Bury Lancs
ML350
No wonder 350 air filters are as expensive as they are, you seem to have half the filter housing incorporated with the filter itself. Why can't MB have designed an air filter that just replaces the filter itself?
Capra
Capra
Gloucestershire
  • #18
Part of the MAF filter plugs directly into the new filters as well.
EmilysDad
Bury Lancs
ML350
On my R Class, the Y piece that joins the two air intakes with the turbo inlet had a small piece missing at end where a jubilee type clip was. I assumed that it would be separate from the 2 MAF sensors but was wrong. The whole thing was a few hundred quid .... needless to say I lived with the original part.
