rf065
- May 30, 2007
- Location
- Grossbritannien
- SLC300 - C250d Estate 4 Matic & Z900rs
I've checked the manufacturers site which was a waste of time, so I'm posting here as I'm more likely to get an answer to my problem.
I've got a Clarke Ranger air compressor that sits in the garage. It is the type that pressurises the tank and then switches off, and it will switch on again when the air pressure in the tank drops.
Recently it has refused to switch off and the pump runs until it reaches 8 bar and the safety valve opens. The safety valve shuts again when the tank is down to 6 bar, but the pump is still running and it goes back to 8 bar and so on. Any ideas? Can I fix it myself or where do air compressors go to for repair?
Russ
Russ
