air con condensor
alangypsy
Hi the forum, went to get air con gassed today told condensor has a hole in it, can anyone tell me how much condensors are and is it a big job to diy.
It makes a difference if we new what car it was for.
Malcolm
Sprint'n'Go
Ashton-under-Lyne, Near Manchester
In my opinion air-con is not really a diy job. Sure you could probably buy the parts and fit them yourself but you would have no way of knowing if everything was sealed properly until the air-con specialist started to re-gas the system (they should put a deep vacuum in the system for a length of time to check the seals, if the pressure is maintained then all should be ok). Much better to let them do the work and accept responsibility for any problems. It shouldn't be a big job, unlike the evaporator which is usualy buried deep within the dash!
A
alangypsy
sorry, should have stated it is a c class 250td reg in 1998
nh2
Just had my condenser replaced, incidently the filter / dryer was replaced as well, as at this age it would be false economy not to. basically it cost me £400 all in by getting an a/c specialist to do it all for you usually they guarantee parts & work for 12 months.. this was on a 1998 e320
now the system is so so c c ccold....
condenser's usually fail due to corrosion or holes from stones etc.
i would get it done very soon, as (i'm told) if air moisture gets in it could mess up your entire a/c and then it would cost lots more..
Wise words.good price
malcolm
Who did you use and where are they based?
