I have a C Class 250 Diesel the air conditioning, heating / de mister has stopped working I have checked the fuses but cannot find a blown one....any ideas??
Check the fan regulator. Fans generally go forever, but the regulators often give up. If you locate the reg (not sure where it is on the C), you can check the current from the switch (variable 0-7v ish) and the main power feed. If all ok going in and nothing coming out - you have your answer.
