Air Con fault CLK, HELP!
Status
Not open for further replies.
Ken-CLK
New Registration
S.Wales
I have a problem with my air con, it works only on the drivers side, passenger side blows only hot. I can't use any of the air con controls unless its in the off position...otherwise it blows hot! Also, there was a large pool of water under the car after a 164 mile journey. The belts are all tight, and I noticed there are some air bubbles when put onto the on position when looking into the spy glass under the bonnet. Any ideas, and what cost?
Cheers
Ken
talbir
London
The pool of water under the car is perfectly normal - it's the humidity in the air which is collected and drained harmlesly under the car. It's when you've had AC running and don't have water under the car that you need to be worried.
It may just be a faulty climate control seletor panel, not triggering.
Status
www.W140.co.uk&www.r129.co
