Air con question
Martin blackett
A class W169 1.5 2007 2006 2005
Hi all
Can anyone answer this
W169 2007. When go for regas it won’t hold vacuum. Large leak. Tried to override but machine said no. Leak to large. Put in nitrogen and attached a gauge to the port. No pressure loss show on gauge after 24 hours.
next job is to uv dye it and put nitrogen back in to hopefully find.
Sprayed all pipes and joints we could find with a gas detector and fitted new condenser and dryer new o rings etc.
Seems odd to me the untrained why the nitrogen is still showing on the attached gauge.
thanks
SL63 Mark
The South
R231 SL63 AMG
I'm no expert, but maybe the Nitrogen has a larger molecule than the A/C gas. Maybe it doesn't want to escape.
UV dye is the way to go. I have never heard of Nitrogen test. Seems to waste 24 hours for no reason.
M
Martin blackett
Usually a compressor shaft lip seal, which holds under pressure but leaks under vacuum
Thanks. Is that a major job ? Or just change the compressor. I presume it would show uv due would it ? Where in the comp is it located ?
thanks
Botus
S500/2010/500
nitrogen is much bigger than air... but u don't get air in a AC system. No idea what size that stuff is.
I would expect the condenser is worn out....
M80
Derbyshire
If the condenser has a hole it should be apparent with the nitrogen test.
While mt it might be worth replacing the pressure sensor.
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
thanks
Sadly won’t show UV dye, and will leak refrigerant very slowly but will not hold a vacuum to pass a test on a wheelie bin AC machine.
Best option is a new compressor but also worth getting an AC engineer to run an ultrasonic vacuum leak detector over the whole system before spending money.
Vacuum is a strange test, lowering the system to 300 microns is nothing like the pressures when the system is running and puts very different stresses on the seals.
You need a proper AC man, not a button presser with a machine he got 10mins training on.
M
Martin blackett
does anyone have a table of how much gas and pag oil the system holds
A150 2007. Manual air con. Thanks
