air con question
jandhiluk
If the air con is on, when the ec light is off.does that mean i am getting the worse fuel return,because ac running all the time???
clk 32o cab
thanks
Hilary
alan782
Poole
E320 cdi (211) avantgard estate zzr1400(2012)
Yes it does as the engine now has the added load of the ac compressor. souldnt be too bad on the mpg though, prob around 4/6 mpg.
jandhiluk
si should i turn on ec light when i use the car when i don't require the ac?
seems soooooo complicated !!!
The compressor on cars since 2000 roughly runs all of the time, you must remember that though it is switched on all the time, it is only using a little energy to drop say the outside temp from 25c-30 down to 22c, so although having it running all of he time may cost an unmeasurable amount of fuel, the windows will not mist up and the driving is much nicer with it on. 90% of us leave it on all the time
mikestrivens
Stockport
EC stands for economy mode and turns the aircon off when the EC light is lit. It is done this way to remind you that the aircon is off. However, if you run it off for extensive periods of time you run the risk of having seized compressor and valves which are far more expensive to replace that the tiny extra cost of fuel used by keeping the aircon running. The other advantage of keeping the aircon running is that it keeps the car nice a dry during the winter. No steamed up windows and damp carpets, as well as keeping all the aircon components running sweetly. I and all my friends leave the aircon on with neglible affect on fuel consumption.
