Air Con. The actuator motor for the RH Blend air flap has a malfunction. There is a mechanical fault.
John77
E200 Estate 2011, 2009 SLK 200
Hi plugged my car into ICarsoft for a different problem and it says Air Con. The actuator motor for the RH Blend air flap has a malfunction. There is a mechanical fault.
The aircon seems fine and blowing cold, what could have caused this?
2011 EClass 200 CGI Estate.
harrye500
Cheshire
2010 A207 E500 (the Summer Car and Winter Garage Queen)!
I would reset the code and see if it comes back. Does AC work in all configs i.e. screen, face, feet etc etc?
John77
I will check that
