When was it last regassed and do you leave it on all the timeThe air con on my 2011 C207
is not blowing ice cold air, in fact it actually seams to by blowing warm air at times.
Any ideas, please.
It was last regassed about Two years ago, when I got the car, and no I don't leave it on all the time, in fact don't really use it much at all.When was it last regassed and do you leave it on all the time
I leave mine on all the time unless using the sunroof in which case not worth trying to cool the earth
Doesn't quite work that way....Having said that the earth could do with a touch of cooling at the moment.
As said above buddy , leave it on or you loose more gasIt was last regassed about Two years ago, when I got the car, and no I don't leave it on all the time, in fact don't really use it much at all.
Yep, just leave it on , it also drys the air in the winter as well as cooling in the summer . The aircon regas monkey will also tell you the sameSo is that the solution, Wighty, a re-gas then use it regularly.
I use mine with the roof off completelyFunnily enough had mine regassed by a local mobile unit yesterday, he advised the system had lost 35% gas which according to him was good for a 12 plate car that hadn’t had any attention to the aircon since build. Took the car out last night which was a good test and all is back to normal nice and cool in the cabin. The worst offenders re loss of gas tend to be accident damaged cars apparently which was worth knowing
Ditto on all ours.I use mine with the roof off completely
Never turn it off, does a great job of drying the air in the winter months so the car demists faster. Use it or lose it
£60.00 Seems to be the price for a re-gas, any suggestions,
Kwik fit, any good?
F1 Autocentres etc
Or a small independent specialist.
I used Kwik-Fit to re-gas a car the other year. The kit they use makes it fool proof .....
