joderest
- Apr 16, 2018
- ML270 2003
The air con on the wifes Mini had ceased to blow cold, it is 5 years since i fitted a new condenser and had it re gased, so thought it would just be low on gas.
Took it to the guy that does our air con, and he reported it had a decent amount of gas in it, it should work. He hooked up his scanner and it showed no faults, so bless him he looked further.
He found that the wiring loom that goes to compressor had dropped down, and one of the wires had been rubbed through by the pulley, which blew the fuse. He repaired the loom, hooked it back up out the way, replaced the fuse, re gassed and all good.
So its not always a re gas needed !
