Tomkinsm said:Hi,
Its time to change the air filter element on my 300CE-24. Options are:
K+N £67
Merc £37
German and Swedish £18
Can anyone recommend which is the best option? Is the K+N really worth the money? Is it suitable??
television said:KN do not make one for the 3.2 liter V6 from 06 98. I would have liked one but there we are.
Malcolm
Thank you for that. The price is fine as MB want £45 for a paper one, well two as they are twined.clive williams said:Malcolm,
The K&N filter you require is # 33-2747 for the 1998 E320 3.2L V6 fuel injection.
I bought a K&N for the IL6 3.2 Diesel, which should have been slightly more difficult to source but once I had the part number the shop, Motorworld of Hinckley, Leics had no problem in obtaining one in two days.
Check out the web site www.knfilters.com for dealers, they require country and post code. I use the international site as its easier than the GB site.
Clive
500E
E320CDIT210
PS Mark, I think your part No. is E9179. It looks like a complex filter. Check out the site above for the filter and dealer but £67 sounds a bit high. It might be worth shopping around. I found internet sites much more expensive than the local high street dealer.
television said:Thank you for that. The price is fine as MB want £45 for a paper one, well two as they are twined.
Malcolm
malcolm210 said:Clive,
How do you fine the performance of the 3.2CDi engine with the K&N filter fitted. I'd like to fit one as I've used them before but am a bit concerned about the MAF reaction to it. I assume everything is working OK, if so can you supply the K&N part No. for a 2000 CDi, I would imagine its the same as yours.
Malcolm
malcolm210 said:Thanks Clive,
After checking the K&N website I found a part no. I'll fit one at the next service.
Regards
Malcolm
malcolm210 said:If your not in sales Clive you should be.
Malcolm
clive williams said:Well sort of. I won't give you my profession but it contains a lot of BS.
Clive
500E
E320CDIT210
