Air matic problems
Lj wild
Nottingham
S class 320cdi
Hi hi have a s class320cdi 2002 just put a new air pump on . The car is sitting at max ride hight will not go to normal ride computer says pressure release valve fault but it is new with the pump . Can any one help please
S.Speed
Lancashire
Older Citroen Now :-(
If you alter the ride settings does anything happen ?
If its new then there will be a warranty..
Can I ask how hard it was to fit?
Just a thought though I may be clutching at straws.. Does a new air pump need coding in with STAR ??
Cole@MBS
www.mbssouthampton.co.uk
Wiring breaks on the plug, tug the wires to see if they break.....
L
Lj wild
Nottingham
S class 320cdi
It is easy to fit take wheel off inner wing arch off and under cover gives more acces if you don't have a car lift
L
Lj wild
Nottingham
S class 320cdi
Hi have gave the wires a tug but seem in good order . When the car was sat on its arse with car saying car to low stop had to get a mechanic with reader to clear fault then pump kicked in but didn't stop at normal ride hight went up to max hight . Then car says airmatic visit workshop
www.W140.co.uk&www.r129.co
