coxie
Please can anyone tell me the location of this box on a w211 2004 320 cdi avantarge estate Mercedes-Benz W251 Suspension Height Control Module A2515450432
Thanks in advance Ian
Thanks for the reply i have searched that area and there are 3 boxes 1 a junction box and the others are not the control box i am looking for ... I assume you are referring to the boxes under the carpet fixed to metal plate IanThat module is under the carpet on the passenger side footwell up against the bulkhead.
I have had a star diagnostic and results say it level sensor i have removed and ordered new i am not convinced this is the problem ( buy the way what a crap position for that sensor)That module is under the carpet on the passenger side footwell up against the bulkhead.
Thanks mioba i have removed and awaiting a replacement covid 19 is not helping spares any how i have discovered what is on top of the air bags .....a air solenoid so i have cut the wires and air pipe in rear connected a small air compressor to the pipe and applied 12 volts to the air solenoids and hay presto a drivable car for the time being. i have still not located the position on the air suspension control box its not in the passenger footwell (UK)?????i also think this might be a culpritStar is only as good as the user. That saod if star finds the fault then go for t.
The link rod rusts away to dust too.read this post a few times and don't understand much
the control module is not the sensors... the sensors are on the suspension and the link rod ball joints seize up and this snaps off the senors regularly
Thanks chaps the last basic i applied 12 volt to both rear air bag solenoids by passed the pimp pipe and pumped up rear with a 12 volt tyre compressor .....anyhow part turned up this morning and shall be fitting tomorrowThe link rod rusts away to dust too.
