sweeper
- Jan 15, 2008
- Location
- peterborough
- 2014 Viano 2.2 R350cdi
Ok, so i have had a small air leak for a while now, in fact it was reported by previous owner and checked during a service but no leak was found, so the leak has got a bit bigger so the car drops noticeably over night on the left hand front, I checked the strut for leaks and during that process the hose actually blew off the strut just as i was removing the plate that covers it on the R Class, I must have just knocked it a little, I quickly pushed it home again and it will need looking at (new pipe and fitting) once I have located the leak, as the leak is very small I decided to isolate the strut using a ball valve, just cut the pipe and used a push fit ball valve, run engine and allow suspension to level off and turn the tap off, left overnight and the car was still level.
So the leak is either in the line or leaking back through the valve block, so I bought a new fitting for the valve block and got some 4mm hose (I checked the valve block connection for leaks first, none found) so close off the tap (no need to support the car) and took the pipe off valve end (quite easy to get to on the R, just behind headlamp and no need to remove bumper or wheel arch inners) and put a temporary hose form valve block to ball valve, turn the valve open and left car overnight and it is still sitting level (up during the day due to high temp and down a little when cooler but same both sides) so the leak id somewhere in the line, so i'll put a new line through and drag the old one out just to see where it is leaking. Interestingly my local Mercedes dealer reckons most of the leaks are the lines and not the bags or valve blocks.
