Alarm on W124 1995 Cabriolet..scorpion alarm
harjeet
i am trying to get a master key switch for my alarm.. i have the keys but the main lock has got knackered . i was able to deactivate the alarm with the key which is situated under the dashboard .. but i can reactivate as the lock has one of the pins stuck.. its a round key with a notch on it.. all i wanna do is either replace it or bypass the wires.4 wires in total. which are 2 red wires, mauve with a black stripe and red with a yellow stripe. which wire go together help me please. or if anyone knows where i could get a new lock from .. its not the alarm fob. its the master key cut of switch which is under the dashboard. help help help
pascal
near Dublin
sl320/1999/3.2
Can you get me the no. of the alarm, and I may be able to help you.
H
harjeet
W124 Alarm
Model number is 918
pascal
near Dublin
sl320/1999/3.2
EDITED OUT...... PM me for original
The only **** active wires I see here are '****' and '*****' and one ****(*) from **** to another **** to ***** ***** wire.
There is a circuit between the **** and ****. This circuit interupts the **** switch and the ****, so it is the ***** circuit. It must be **** to start the car.
The *** **** are optional, it seems. They disconnect the **** control from the ***** via ****
Disconnect power.
Join **** *******.
This should turn *** **** switch.
Reconnect power
Turn alarm off with fob
Pascal
PS: Not leaving this info on the board for too long.
KeithPW124
Key Fob Blues
The above may be of use to me except it has been edited.
This is an excellent site and has been a great help so far today. However, I am stuck!
I have a 1991 300TE with a Scorpion alarm model 918. The key fobs both refuse to work and alarm will not reset. I have switched it off manually with the barrel key but then the car turns over but refuses to start.
I have tried holding the fobs on for 30 seconds. I have tried disconnecting the battery and attempting a reset. I have even tried reasoning with it! All to no avail.
Any ideas????????
:confused:
shayes
as stated
I just sold a couple of keyfobs to a defunct Scorpion alarm on an SEC that I owned some years back. Took off various parts and as I say, thought perhaps the fobs could be useful to someone - guy crushed his fobs so very grateful as presumeably (?) can have them re-coded.
I have a key which is circular and hollow with a small engaging prong. From memory, it goes into the block of the system which was under the bonnet.
I am not sure if it is a standard key or one of several billion slightly different keys.
It has a number on it IS5061.
Anyway, seems as though you need to personal message the moderator to get the full sp of what you are seeking.
