Alarm problem
RoyDavis
I was driving along tonight and all of a sudden the alarm goes off :confused:
I pulled over and turned off the ignition, tried locking it and unlocking it and but the alarm just carried on, it stopped on its own for a few seconds and then started again. I tried everything i could think of to stop it and in the end it just stopped on its own and stayed off for the rest of the journey.
Any ideas why it did it and how i can stop it from happening again?
Is it a 203,,it looks like it in your picture
RoyDavis
RoyDavis
Yeah it is a 203 Malc, the amount of problems im getting with it at the minute are starting to get to me!
Could just be the siren faulty,,see what I have on it
Cole@MBS
www.mbssouthampton.co.uk
Seeing this a lot, siren been up-dated again, most common on a 203!
RoyDavis
RoyDavis
It has gone off a couple of times for no reason while being parked up but not while ive been driving along! I had images of being chased down the road thinking i'd stolen it! I get enough of those looks as it is without the siren going off aswell!
Cole@MBS
You need a new siren Roy, new part number is A2198203226, that i know because i changed another one yesterday!!
SQ_W211
W219 CLS55 AMG
SAM is that the same part number for W208 CLK or it differs on C class than CLK. Mine dont go off at all. when i trigger the alarm by opening the door manually the blinkers go off to indicate that the alarm is going off but it doesnt actually make any sound.
could this be Siren too
RoyDavis
RoyDavis
Ah really? The amount im spending on this damn thing is crazy!! How much is a new siren gonna set me back? One thing i noticed aswell is that when it was going off while i was driving the hazards wasn't going off at the same time, any reason?
And is it likely to go off while driving again untill i get a new siren?
SQ_W211
W219 CLS55 AMG
I have issue with my siren too, new siren from MB is around £40 odd but not sure, i have only been told about this by senior forum member so dont hold me back on the price as it is only an estimated price
As the flashers were not operating when the alarm sounded that show really that it is only the siren at fault
The excessive rain did not help these thing much this year
stevesd08
SL 500 R230 alarm problem
HI all, I suffered the same with my alarm the other day alarm just went off i could not stop it with the key, siren stopped on it own lights flashed for a short time afterwards, it did this twice but now it still go's off but just the flashers flash but can be stop with the key is this a siren problem or something else if so is there anything i can do and were is the siren.
thanks steve.
Hi Steve and welcome,, ther are movement sensor and interlocks on the 230, it could be something with those, we have never had this yet on a 230. I will check to see if there are any known issues
The only thing listed is on the 230.
Do not leave metal objects in the center box as this can trigger the alarm.
Do you have any water in the boot, lift the cover and check for any water stains
stevesd08
alarm r230
HI Malcolm yes i do have a metal toy in the center consul box but has be in there for 6 months , I have had water getting in the boot in the past this was made worse when i asked main dealer to look at it they pulled away all the back seal around the boot which broke the double sided tape seal, i got some more and replaced it only thing is they never told me what they had done just its best to replaced the whole seal, up to date has been fine that was 4 months ago but i will check, also were is the siren. thanks Steve.
I will be doing an article on sealing the roof on these cars shortly. Water can cause the alarm to go off.
The siren is under the wheel arch liner, I need to check what side as many components are on the opposite sides on the SL owing to the ABC components.
My washer bottle is leaking and I am taking off the drivers side arch over the week end and I can see, or I can set mine off in the morning.
http://www.detali.ru/cat/oem_mb2.as...GA=722.633&CT=F&cat=65P&SID=82&SGR=530&SGN=20
Cole@MBS
Near side at the top, changed one last monday!
stevesd08
alarm r230
HI , thanks to you all for your replies to the alarm problem , and i will look forward to your post Malcolm on the leaking roofs i do still have a very small leak on the top nearside front were it joins the front window screen and side windows. thanks Steve.
Steve as this is the front part of the roof, I have sent you an Email and paper to fix your leak
