All is Well - Almost!
Joreysdad
1998 w210 estate
Got my new ML 430 on Friday - great day to pick it up.
Have had a loveley weekend burning up gallons and gallons of fuel but I do have a problem it seems.
When I test drove the car, I booted her on an open stretch at around 40mph and she jumped down a gear or two, and lost all power. Couldn't get her going again properly and at idle she felt rough.
Told the salesman when I got back from test drive, who jumped into her, started her up and took off down the road with no trouble.
So as part of the deal I insisted that she went to MB or a specialist to be serviced/checked over etc.
Said specialist insisted on a variety of things being done, such as new discs/pads, tyre etc and sorted out a new mirror switch, an a service and most importantly fitted some sensors which were the cause of the loss of power. Cost the salesman 750 quid and I'm a happy bunny.
Only it appears the sensors weren't the problem. Once during the weekend (only once mind you) when I tramped the accelerator at about 45 to get out a lane and up a hill in wales the same loss of power occured :(
No worries though - pulled over, she was idling rough, turned her off, turned her on and presto all was well :)
I had pressed hard enough to hit the kickdown button under the accelerator so I don't know if that was the problem?? (Did it before the event and she was fine from a standing start - hyperspeed achieved no problem)
Any ideas anyone?
Oh and one other thing - where can I get another remote type key? Only got one :(
Why not unplug the MAF filter and see if it runs better or take it off and clean it as the threads here. the engine may run a bit rough with the MAF unpluged but your other problems may go away. You ca buy a Bosch insert for a fraction of the price of one from MB
Sorry forgot the key,only from MB,take your passport and log book with you.
Malcolm
Joreysdad
Joreysdad
1998 w210 estate
Thanks - is the MAF the same as a MAS? And how much is it going to cost the garage that sold the car to me? :)
Yes it is the same thing. from Bosch £58 from MB £250 + fitting. from Bosch you have to use the existing plastic housing,and there is nothing wrong with that.
Malcolm
Joreysdad
Joreysdad
1998 w210 estate
Does removing the MAF affect fuel consumption? - I ask as the car went back to the garage and was "fixed", all being well power wise, however she now runs slightly rough on startup when using petrol and I seem to have poorer fuel consumption. I'm wondering if they have just took it out!
