rallen
- Aug 29, 2005
- E320 2001 / CLS 320 2007 / SLK 280 2006
Hello
The car displayed this warning today and all lights appear dim and engine is not running very smooth.
Came back from work, measured the voltage with engine on, about 10 Volts, revving made no difference. It should be 13.8V with engine on so seems like alternator is dead? But I read a short battery cell may cause same behaviour. I will try to run the engine on another battery.
Failing that I looked at the alternator (it is getting rather dark outside) and could not see any obvious "regulator" component I could perhaps pull out and repair/replace. Any ideas where such a component may be located? Are there any relays/fuses perhaps that might cause problems?
This is a E320 2001-2002 estate petrol engine.
DOh! engine off and the battery voltage is shy off 12 volts, looks like the battery is good... I do not even knwo where the battery is (trying to find it)
many thanks
many thanks
