always on stereo unit
tismehi
I have a '99 e300d and I have just fitted a new jvc stereo unit with bluetooth, front usb and aux in.
I would like for it to be able to be powered on at all times - ie, without the key.
is it a matter of joining the permanement live wire to the one which powers up when I turn the key?
or is there another way to do it? maybe through the fusebox?
cleverdicky
MB
Yes that would work. But you risk draining your battery.
Make sure you have a fused supply.
As cleverdicky with inline fuse so just join both 12v plus together
M80
Derbyshire
In your case I would consider linking the 2 feeds by an override switch. Off- normal, on- unit on while ignition off.
A bit of clever wiring through a relay could drop the relay and link whenever the ignition switch is turned preventing a flat battery you forgot.
T
tismehi
thanks guys,
your advice was a help.
i connected the unit by cutting the yellow ign feed yellow wire and joined it to the permanent live red wire.
i fitted an inline fuse at this point and it works exactly as i wanted it to.
cheers again.
