AMG MCT Paddles in Comfort Mode
Jason63
C63 AMG
I have the 7G speedshift MCT gearbox. I find it pretty good for an auto. I fully understand the C, S, S+ and M modes. They're exactly the modes I'd want too.
What I don't fully get is this, and I'm not seeing the answers in the handbook or elsewhere.
If I'm driving along in Comfort mode and I need to overtake I can:
a) Accelerate hard. The gearbox will kick down and off we go. There is however a small lag as the gears are changed, it also makes a huge show of the overtake with the revs and exhaust noise.
b) Look down find the gearbox setting dial and change into say S+ or M. Then when the moment is correct overtake. Faster overtake, less fuss but it's a bit of a faff to prepare.
c) My preferred option, see the opportunity click down a gear or two with the paddle and go. Fast, intuitive and controlled.
However after (c) the car is showing the gear e.g. D4 and C for Comfort. Now what happens? How do I revert to Comfort? The car seems to stay in that gear, although it will change down if the speed drops too much. I think it won't go above the chosen gear e.g. D4 but I'm not sure.
Am I in Manual Mode? Am I in a Comfort version of Manual mode (with slower gear changes)?
How do I get out of this mode? I can do it by selecting M then back to C but is there a better way?
The 9G box I had would revert to whatever mode I'd previously chosen after a few seconds. I'd go down the box on the paddle like you for an overtake them come back up the box as far as possible after the maneuver and then leave it alone and it would revert.
Mine wasn't an AMG so I don't know if your's is programmed differently
Jason63
C63 AMG
It doesn't seem to revert to C mode but perhaps I've just not left it long enough.
Have you gone "back up" the box first?
dry run
Portsmouth
kb-boatpark.co.uk
CLS 350d AMG LIne Premium Plus
On mine, I simply rapidly flip the "+" paddle until it goes back into "D" with the mode I started in.
A.J.
Norwich. UK
I think it automatically reverts to Comfort mode after 12 seconds. Alternatively I think you just hold the + paddle for a few seconds :) Can't guarantee that is what happens on an AMG though :rolleyes:
Graveworm
AMG E63S 4Matic + Estate 2018
Yes all of these, and you can also knock the column into D again.
EmilysDad
Bury Lancs
ML350
I dont have comfort mode but mine goes back to auto after a few seconds unless I'm using a lower gear for engine brake etc in which case it'll stay in the lower gear until the car is on a level again. And as above holding the + paddle for a few seconds it'll go back to auto ie D5 etc
Jason63
C63 AMG
Thanks. I'll give this a try.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Mine is almost always in Sport+ anyway so haven't really noticed this.
Chrishazle
Nr Ashford, Kent
On my SLK in C or S mode, if I decide to use the paddle shift it works without going to M mode ( via the little button on the centre console) so I can use the left - paddle to drop down a couple of gears, but when I hit the + paddle (say I'm now in 5) it changes up to 6 then D (7 speed box) so it's actually very easy when in Auto mode to use the paddles to get overtake or engine braking mode, then easily go back to full auto mode without taking a hand off the wheel!
Jason63
C63 AMG
Thank you everyone.
Based on your replies and a bit of a road test I can report that my car (C63 AMG with 7G MCT) does this:
  • Whether you are in C, S or S+ the down paddle instantly selects a gear.
  • The car holds that gear, there's no timeout, well not within 30s or so.
  • If you use the up paddle the gears go D2 -> D3 -> D4 -> D5 -> D6 -> D7 then D (full auto).
  • If you hold the up paddle the gears count up to D7 then D in a fraction of a second and you are returned to full auto.
As mentioned in the post above that's perfect for a quick overtake whichever auto mode you are in.
rorywquin
North Yorkshire
An old B-Class.
Individual setting for me, esp off, engine/shockers/transmission in brutal setting .................
How is that different from the 'S+' (or whatever is your sportiest mode) setting is?
badger_wazzala
The United Kingdom
63 AMG
In s+ the traction control remains functional. In the individual settings you can turn the ESP off and enjoy more wheel spinning freedom.
Peter Jenks
AMG C63 W205 Estate
It does!!
