AMG wheel corrosion - don’t want powder coating
sl500amgsport
Essex
SL500 2014
Managed to take a photo of each this afternoon, they are a bit dirty but give a good idea of what can be achieved over a couple of days and three of the four were quite bad - nothing looks worse than white powdered corrosion. I’ll be quite interestEd to see how they hold up.
Excellent job looks great!
Sent from my SM-G988B using Tapatalk
rorywquin
rorywquin
North Yorkshire
An old B-Class.
  • #23
Powder coat guys said I can choose any colour (probably going to be a bright silver / chrome look)I like. Any known issues with any particular colour?
Frontstep
T210 320cdi
It depends on his supplier and colour chart one companies super silver might not be anothers.
They usually have some photos.
M80
Derbyshire
Powder coat doesn't last forever, even w/o kissing kerbs.
rorywquin
rorywquin
North Yorkshire
An old B-Class.
  • #26
Yep but it has to beat that corrosion under the clear lacquer? What are the alternatives?
M80
Derbyshire
Personally I'd go powder coat,
that's mainly because of the place I've used in Brum (City Powder Coat) that do wheels starting at £40 each. I don't know how the Brum clean air penalties might change things.
I have been taking the wheels down there when it's time for new tyres. I provide new tyres and the set are returned ready to fit. Tyre fitting is approx £10 extra.
But I've seen the corrosion bubbling beneath after perhaps 4 years or less.
But on yours some wire wool, or as said some fine emery and good laquer might suffice for a while.
rorywquin
rorywquin
North Yorkshire
An old B-Class.
  • #28
I might try that !
Frontstep
T210 320cdi
Just see it as maintenance for having nice wheels.
You could always get steel ones and plastic covers...............................................................
rorywquin
rorywquin
North Yorkshire
An old B-Class.
  • #30
£100/year for having nice wheels ----it’s a thought!
JBell
Torquey
C350 CDi Estate (GAD Edition)
See if they do "Hi-Power" Silver
richlumb
GLC 350d
Even the home use stuff is pretty bad, I’ve been trying to find a cleaner as close to neutral as I can but seem to be failing miserably at the moment
Which ones you tried ? I did a comparison on another forum with the Meguiars, bilt hambler , autoglym and a couple others , since then I’ve also tried the Gtechnic wheel cleaner which is pretty good
V6Matty
Newark, Nottinghamshire
Megs and autoglym so far which is now almost finished so I’ll give gtech a try next,
richlumb
GLC 350d
Bilt hamber auto wheels is probably the best but has a really strong smell unfortunately that lingers , Gtechniq W6 seems to be a good alternative
vtaylor78
Northamptonshire.
I’d like to throw Bilberry into the mix, you can make it what strength you require.
I clean wheels regularly, so only use 1/10 mix .
V6Matty
Not seen that one so I’ll take a look, always like the idea of a self mix solution
richlumb
GLC 350d
It’s one I’ve yet to try as well so be good to hear some feedback on that
Conor
London, UK
38% Hypochlorite is very common amongst the unlicensed hand car wash fraternity… does a great job of removing brake dust, lacquer, paint and alloy…. :shock:
Yea, I saw them using 33% Hydrochloric *NEAT* at a car wash the other day. I was so shocked. I knew they used some pretty strong stuff but damn..
rorywquin
rorywquin
North Yorkshire
An old B-Class.
  • #39
MB have come back and offered to pay 50% for replacement of 3 of the wheels & they keep the old ones. Sounds like an admission of some sort. I’m not happy as they want me to contribute about £1300 to get 3 replaced.
1) What happens when number 4 fails
2) What happens when the same problem starts again in a couple of years
3) They take the old 3, send them back for repainting, and resell (even as used) and lose nothing.
Other than corrosion at the center, the wheels ae almost pristine. I think I’ll fight on and go directly to MBUK.
sl500amgsport
Essex
SL500 2014
For £1300 you could have them refurbished diamond cut twice, that would Probably outlive your ownership of the car....
