I think ur wheels will fit 18s should be ok on an ML the 285 part is the bit u worry about what u need to do is try one on and see it dont foul on the suspension and try it lock to lock, most of the tyre guys will have charts to tell u what u can go up to in size and offset. tho try and avoid spacers if u can cos they ruin wheel bearings and tracking
If they do fit, they will make your car ride rougher and tramline a lot more. The 235 originals are the best compromise tyre for the vehicle for ride and general handling. Saw a motoring writeup on one fitted with bigger wider tyres and it was bagged compared to the performance on 235's. Might look better but .......
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
